SD card of nexus one automatically mount when connecting USB to my PC
This is a discussion on SD card of nexus one automatically mount when connecting USB to my PC within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Before, everything was fine, it's annoying I just want to charge my phone, I have to unmount th SD card to continue to listen music... ...
Thread: SD card of nexus one automatically mount when connecting USB to my PC
    Junior Member angelot's Avatar
    Simply, I want to manually mount my SD card when I connect my nexus one (Rogers) to my PC. Where is the option for that?
    here the last apps i've installed on my phone:
    Aloqa, Layar, Qik, Runstar, Knocking & LauncherPro.
    I suspect LauncherPro to be responsible... (i want to be sure before uninstall it, i don't wanna lose my "desktop" setup)
    I did not install any apps like automount.
    I use at home Ubuntu 10.04 x64 and at work Windows 7 X64
    thanks for your help!!
    Junior Member theSavant's Avatar
    I would also like to know what's causing this. It is disruptive when I plug in my device to charge via usb.
    I had launcherpro but uninstalled it. After uninstall, sd card is still automatically mounting when plugged into usb.
    I was under suspicion that doubletwist was the cause.
    I don't have the issue anymore, launcherpro have released an update since last post. But I just remember that i tried Doubletwist about the sametime and uninstall it...
    Thanks for your reply. Yes, the doubleTwist app was causing the sd card to automatically mount each time I plugged in my usb cable. I just uninstalled it and I don't have that issue anymore.
