connect to GPRS
This is a discussion on connect to GPRS within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; i brought my N1 to indonesia from US and try to use local operater. but it cant connect to GRPS. the only way to connect ...
Thread: connect to GPRS
    Junior Member tiika's Avatar
    Question connect to GPRS
    i brought my N1 to indonesia from US and try to use local operater. but it cant connect to GRPS. the only way to connect to internet is by using wifi. would u help me to sett my phone so i can use it? thx before
    Senior Member rioja's Avatar
    What's the name of your operator in Indonesia?
    You need to find the correct APN settings for your operator in . Do a search on Google for the APN settings for Android. Once you find them go to Settings > Wireless & networks > Mobile networks > Access point names on your phone. Press the menu key and choose new APN (if one isn't listed already, otherwise you can edit that one). Then enter the settings you find.
    If you have problems, please post back here for more help
  1. Epic 4G launches August 31 for $249
    Last Post: 09-02-2010, 08:59 PM
android setting gprs connect
gprs internet.06
gprs-connect-chat android
