Gmail syncing issues
This is a discussion on Gmail syncing issues within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; My N1 hasn't been able to sync since yesterday. It keeps asking for my password over and over again. Is anyone having problems with their ...
Thread: Gmail syncing issues
    Junior Member bayou's Avatar
    Is anyone having problems with their gmail account? I can't access my gmail account at all.
    What did you try to fix it. Search?
    Check your settings that sync box is checked.
    Try powering phone off/on, or then try a battery pull.
    Search Google Forums or even post in help section if above doesn't work.
    Maybe someone else has another option short of removing and reinstalling Gmail. That would be a bummer, since erases other data.
    Ken
    [SIGPIC][/SIGPIC]
    San Francisco Giants
    Quote Originally Posted by rugmankc View Post
    Ken
    Thanks. When I go to settings the Gmail sync button is red and says they're experiencing issues and it will be back up shortly. I just tried to log on to my account through my computer and my account is temporarily disabled. Wtf? When i go through the process to get my account fixed I get a 'we're working on the problem, sorry for the incoveniencen blah blah blah ' message. Grrrrrr.
    Did you speak to anyone or just go thru the prompts.
    Best to actually talk to somebody.
    Good luck.
    Ken
    [SIGPIC][/SIGPIC]
