WiFi sleeps when device is locked!
This is a discussion on WiFi sleeps when device is locked! within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; As the title says, I want you guys to test the new email notifications when the device is connected through WiFi. For this you've to ...
Thread: WiFi sleeps when device is locked!
    Junior Member resplendent2209's Avatar
    WiFi sleeps when screen goes off!
    As the title says,
    For this you've to set the WiFi sleep policy to never and the Background and Auto sync option needs to be checked.
    Well, I don't get any notifications. I went an extra mile ahead and pinged the IP address and found that I get "request timed out" error when device is locked and when it is unlocked, the packets are received properly.
    Waiting for you guys response.
    Thanks and Regards,
    resplendent2209
    Senior Member FC1032's Avatar
    Hi!
    I just did a test with your set out parameters,
    I got an email notification after sending an email to myself on the computer.
    I want you to test if your Nexus one receives new email notifications in that scenario.
    Yes it does.
    Do you mind chatting with me on gmail right now?
    My email id is sunil.extc2209@gmail.com
    Thanks I appreciate your help.
    Sent you an invite =)
