Custom ringtones reset to default after power down
This is a discussion on Custom ringtones reset to default after power down within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Upgraded my t-mobile N1 to 2.2. Now I notice all of my contacts have reverted to the default ringtones when I power off the phone. ...
Thread: Custom ringtones reset to default after power down
    Junior Member RodMyers's Avatar
    Anyone else notice this behavior?
    Senior Member Zehlek's Avatar
    How do you use customer ringtones?
    mp3'a in the /media/audio/ringtones directory.
    I select a contact, select "options", ringtone, and scroll down to select my custom ringtone, then hit the "back" key to get to the contacts main page.
    Is there some other way?
android restore ringtones after reset s3
ativ s resets ringtone to default
ativ s ringtone changes after reset
ativ s ringtone keeps resetting
ativ s ringtone reset issue
custom ringtone reset power off s4
my ringtones reset when i power off my lucid 2
ring droid ring tone resets after reboot
s3 personal ringtones reset when power down
samsung ativ ringtone default
samsung ativ s default ringtone power off
samsung ativ s resets ringtone on power off
wp8 ringtone resets on restart
wp8.1 custom ringtone reset after reboot
wp8.1 ringtone default restart
