My Battery Life SUCKS!
This is a discussion on My Battery Life SUCKS! within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Okay. I turn off wifi when i am out. I have everything update every hour or so. Screen is on auto brightness. setcpu have lowest ...
Thread: My Battery Life SUCKS!
    Member Euforeik's Avatar
    Okay. I turn off wifi when i am out. I have everything update every hour or so. Screen is on auto brightness. setcpu have lowest setting possible for sleep mode. I left the house at 12. Got back at 10 with no battery left. I used it to check the time. played music for about 5 minutes. thats all i did. what should i do?
    Senior Member antikryst's Avatar
    wow theres something wrong there. maybe theres a rogue app eating all your resources. i can get a full day on my nexus (stock and unrooted) with push email/sync on.
    Senior Member gregornz's Avatar
    What does the setting panel say is using your battery? My battery life sucks too, It's hard to get a full day, and usually the display accounts for 80% of the juice consumption.
    Quote Originally Posted by gregornz View Post
    I actually just plugged in my phone. I will report back with the results tomorrow night. Lets see if this thing holds up.
    try to do a full drain until it wont turn on anymore. then charge it overnight. read somewhere here that that helps calibrate the battery so the nexus knows the real battery readings.
    tried it and it actually worked for me.
