Phone Crashes When Answering a Call
This is a discussion on Phone Crashes When Answering a Call within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; So far, it's happened twice in 2 days... I saw a call coming in, swiped the "Answer" bar, and all I heard was a "buzzing" ...
Thread: Phone Crashes When Answering a Call
    Senior Member Gwhiz2k's Avatar
    So far, it's happened twice in 2 days... I saw a call coming in, swiped the "Answer" bar, and all I heard was a "buzzing" sound, then the phone re-booted. Crashing like that is much worse than while playing a game or something, because I lose an important call...
    Has this happened to anyone else?
    Junior Member Fromm's Avatar
    Yes, it did happened to me 2 times in the first 2 weeks, but since then I never got this problem!
    However there is also problems like the phone restarting "rebooting" it self for no reason! or just it turns off! like today for the first time for me! and I tried to turn it on, but it didn't work, I had to remove the battery to make it work!
    Junior Member oleg_mamaev's Avatar
    Same problem from the very start! The phone just hangs on random incoming calls; sometimes power button solves the problem, but usually only replacing a battery fixes the issue :-(... upgraded from 2.1 to 2.2 Froyo adn tehn to the next build. Alas, no difference - must be a hardware issue
crashing while answring the phone
