Please help!
This is a discussion on Please help! within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; while trying to downgrade I accidentally installed the AT&T update ERE36B and I have a T-mobile phone. I am now trying to downgrade to ERD79 ...
Thread: Please help!
    Junior Member dpuvince's Avatar
    Please help!
    while trying to downgrade I accidentally installed the AT&T update ERE36B and I have a T-mobile phone. I am now trying to downgrade to ERD79 but when I try to flash it I am receiving an error that says "main version is older!" when trying to passimg.zip the stock rom. I am not sure if it has any relevance but when I choose the recovery option there are a few errors that pop up before moving on to the next menu. They seem to be searching for a passimg.zip but say it is not found.
    The errors are something like this dueling the bootloader
    loading passdiag.zip
    no image found
    loading passdiag.nhh
    no image found.
    PLEASE PM me with ANY help
    Member killerbender's Avatar
    you should do a stock recovery (factory reset)
    I did that but it does not change the build
    try to upgrade to epe54 again.. thats a greater build compared to the one thet you have. You have to go to a build that is newer to the one you have, otherwise it says is a older build.
    btw how so you got to that?? what did you do?
    Quote Originally Posted by killerbender View Post
    I dont even remember where I got it from anymore... I just got off the phone with tech support and they are confused on how I have this build number but the stock 2.1 Kernel
