Call Waiting Question/Issue
This is a discussion on Call Waiting Question/Issue within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Ive noticed now that when I talk on my Nexus and end the call, Ill look at my screen when it hangs up and sometimes ...
Thread: Call Waiting Question/Issue
    Junior Member Miko's Avatar
    Angry Call Waiting Question/Issue
    Ive noticed now that when I talk on my Nexus and end the call, Ill look at my screen when it hangs up and sometimes It says I have a missed call and I could never figure out why because I would have heard the call waiting sound. So today I tested my phone by calling my voicemail from my Nexus and then Calling the nexus from my Home phone at the same time & what I found was The screen would show I have a call for a split second but no sound/vibrate notification would go off & it would automatically end the call & on my home phones end I get a busy signal. I already made sure my "Call Waiting" box was checked in the Phone settings. I am rooted & using a custom rom could that be the problem? Any Advice would help. Thanks guys
    R.I.P. Nexus..
    Rooted w/ CyanogenMod 6 Final Build
    [Amon RA Recovery 1.9.0 Alpha]
    ___________________________________
    Coming Soon Samsung Vibrant..
    Member raccord's Avatar
    I've had the same issue too. I never hear a call waiting sound when in call
    Is your phone rooted and are you also using froyo?
    R.I.P. Nexus..
    ***UPDATE*** Just got off the phone with Tmobile and they said they are experience problems with Incoming Calls in general. It went from me not recieving Calls that were Waiting to ALL incoming calls getting a busy signal. The rep tested his phone to call and even he got a busy signal when calling my phone. They said the fix should be completed soon so looks like its just a problem with the network and not the phone.
    R.I.P. Nexus..
andriod phone show busy on incoming calls
android call waiting issues
nexus 4 call waiting notification
