Cant silent my Nexus after Froyo
This is a discussion on Cant silent my Nexus after Froyo within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I posted in a thread earlier today about the same issue but received no response so maybe I get more luck here in this section. ...
Thread: Cant silent my Nexus after Froyo
    Member Kits2GR's Avatar
    I manually updated my Nexus to Froyo FRF50 when it first came out. I noticed now I cant silence my phone, only vibrate. Usually it goes from loud to vibrate to silent when I hit the volume down button. I know there are several settings but none of them seems to work, either loud to silent or loud to vibrate.
    Also, I noticed my keyboard is missing the .com button when typing in the browser.
    Is anyone else having this issue?
    Junior Member mischievouslibra's Avatar
    Yes, Im having that issue too..Please someone help
    With the Froyo release they added a setting in the Sound settings named Vibrate. This was added in and has settings to control when the phone will vibrate. I have mine set to Never for vibrate and that put it back to before Froyo state.
    Now for the .com I noticed that left the keyboard too.
    Yeah but is there a setting that allows it to vibrate with sound, then goes to vibrate only, then silent when I hit the volume down key? that was pre froyo for me. There are 4 options on the vibrate setting, Always, Never, Only in Silent Mode, and Only when not in Silent mode. None of them puts it to silent except "Never" but that just skips over "Vibrate".
    Quote Originally Posted by Kits2GR View Post
    I didn't use vibrate much, but I believe that is in the individual app settings. i.e. in the Gmail app, you can set it to vibrate when it rings for an email coming in. Not sure how you'd set that for phone ringing though.
android phone skips vibrate mode on volume control
