Bug with handsfree not working in vibration mode
This is a discussion on Bug with handsfree not working in vibration mode within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hey Froyo issue: Say I have my N1 on vibration mode and listening to music through my handsfree. If somebody gives me a call the ...
Thread: Bug with handsfree not working in vibration mode
    Senior Member elvis1's Avatar
    Hey
    Froyo issue:
    Say I have my N1 on vibration mode and listening to music through my handsfree. If somebody gives me a call the phone vibrates but I can't hear the ringing! Furthermore, the answer-button doesn't work!
    If I enable sound, the answer-button works and I can hear the ringing, but now the phone itself also rings so everyone else can hear it too! This is super-frustrating!
    I use Klipsch s4i headset and the Setting Profiles app.
    Anyone?
    Junior Member wilshere89's Avatar
    Same issue as above in Nexus S 2.3 gingerbread
    As you have described, I am facing exactly the same issue but in 2.3 Gingerbread OS.
    However, my friend's Nexus S works absolutely fine regarding this issue without any problem , so I am guessing it's few select models which have this issue.
    Did you ever get any resolution to the issue? i couldn't find any solution on the internet as such. It doesn't seem to be a widely reported problem
    No, I didn't. I don't think there is a good resolution.
    What I ended up doing is the following (using "Setting Profiles"-app): Whenever I connect my headphones I activate my "music-profile". This sets the ringer-volume on the lowest level. In this way, I can hear the ringing through the phones, while the sound is probably too low for anyone else to hear it.
    Good luck!
    Btw: I find it odd that no one else is experiencing these problems!!
    Yeah it is very weird. You are the only person I found having this problem online.
    We are probably the unlucky ones.
    Anyways, it's a minor irritating bug. Thanks a ton for referring the 'Setting Profiles' app. I have done the same thing now, so should not face much irritation.
android ringing handsfree
handsfree button doesn't work on android
