Using Nexus one as a modem
This is a discussion on Using Nexus one as a modem within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi, Can anyone advise if i am able to use my Nexus one as a Modem so i can access the internet on my Laptop ...
Results 1 to 10 of 11
Thread: Using Nexus one as a modem
    Junior Member Simon Brooks's Avatar
    Hi,
    Can anyone advise if i am able to use my Nexus one as a Modem so i can access the internet on my Laptop if i am not able to connect to a LAN or wireless network?
    Thanks
    Simon
    Metro Atlanta
    53 times
    If you have FroYo, go to Settings>Wireless&Networks>Tethering & portable hotspot. From there, you can either activate USB tethering, or wireless hotspot access.
    If you're not on FroYo yet, look for PDANet in the market and install it, as well as on your laptop. It will give you the same options.
    Hey,
    Thanks for that, i have just downloaded and installed the software both on phone and laptop and it is all working,
    Thanks
    Simon
    I know its a complete change of subjecy but an you advise when version 2.2 of android is going to be released on the Nexus one please.
    Simon
    How do i check if i have Froyo enabled on my nexus one? i thought that came qith version 2.1
    Metro Atlanta
    53 times
    Quote Originally Posted by Simon Brooks View Post
    It did. Go to Settings>About Phone, and scroll to the bottom of the screen. You'll see Android version and Build Number. If you're on Froyo, you'll see version 2.2, and build number FRF91.
    BTW, there is a delay in Vodafone releasing 2.2. There are threads here that can instruct you on how to download and install Froyo, regardless of the Voda delay.
    Junior Member bigdaddybatonrouge's Avatar
    I just wanted to comment, "You Administrators ROCK"!!!!
    Thanks so much for taking the time to answer questions and address problems we "newbies" encounter... By reading yall's/your comments, I am getting the most out of my nexus one and RUNNING CIRCLES around all these damn iPhones my friends have...
    Thanks Again!!!
    Jacques'
    62 times
    Hey Simon! Search for a thread by Sir 'Floogle' about upgrading your phone manually to FroYo...it's really not hard..just be patient and thorough.
    Here:
    http://www.nexusoneforum.net/forum/n...lds-frf91.html
    Android Lurker pewtavert's Avatar
    Staten Island, NY
    What does froyo do? Is it just the latest software update?
    Metro Atlanta
    53 times
    Yes, FroYo is the latest software, also known as Android 2.2. What it adds to this question (among many other things) is the ability to use the phone as either a wifi hotspot or tethered (by USB) modem.
config nexus modem?
google nexus as modem
how to use my nexus one as amodem
how to use nexus as a modem
how to use nexus s as modem
htc nexus one modem
laptop modem using a nexus 4
nexus one modem
nexus one usb modem
using google samsung nexus as modem
using nexus 4 as modem
using nexus s as modem
modem nexus
