Problem with Froyo and (built-in) Twitter app -- force close
This is a discussion on Problem with Froyo and (built-in) Twitter app -- force close within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Originally Posted by keyplyr Originally Posted by WERA689 Make sure you look under the "All" tab, instead of the default "download" tab...you'll see it there. ...
Results 11 to 17 of 17
Thread: Problem with Froyo and (built-in) Twitter app -- force close
    Metro Atlanta
    53 times
    If you're speaking to me, yes I've looked. No Twitter app. I'm glad I don't have it... 'course now that I've publicly acknowledged this it will likely appear next time I look
    Yeah, I was. Can't explain it, because it definitely showed up with Froyo on mine. shrugs
    Hmm.. I use the Twitter app on FroYo with no issues at all. I'm not sure what could be causing your issue.
    Junior Member bongster's Avatar
    Quote Originally Posted by Sheanzy View Post
    @Sheanzy,
    Before Froyo, when you were on Eclair, did you have the Twitter app installed? Or did you download it from the Market after your Froyo update?
    (Since some people are seeing Twitter app on Froyo installed magically), My guess is when the Android upgrade to Froyo happens, Froyo installs the Twitter app as a built-in app (in /system/app directory) if it sees that Twitter is installed already.
    Android Lurker Snickolaz's Avatar
    Missouri
    I know I had the Twitter app installed on my phone before I had the Froyo update. I used it all the time, and I still use it all the time. Haven't had any problems with it before or after Froyo.
    Android Lurker BayRican's Avatar
    i never had twitter app i used twicca. but this twitter app came with FroYo updateto my phone and cannot uninstall also the app is growing in size and i have to keep clearing the data
    @Sheanzy,
    I installed twitter from the market because I wasnt a fan of twidroid. It works fine with no force close. hmm?
    --> Ne:nexusx:uS One ROOTED
    --> ...a Gingerbread ROM
    - Our handicapped puppy -
    *Follow me on Twitter
    EASY ROOT + CUSTOM KERNEL FLASHING INSTRUCTIONS ----> HERE
    Junior Member jockah's Avatar
    I had the same problem. When I tried to open twitter app, I got an error forcing the app to close. And I had the twitter app installed before the Froyo update.
    I solved it removing the twitter account from the "accounts and sync" menu, in the Settings menu. Look that the account appears twice instead of once, and qhen you remove one of them, both gets removed... sorry if I said the menu's names wrong, but I configured my phone with other language and the translation sucks very often (as my english skills... lol)
    Hope it'll work for you too.
twitter app force close
