Problem with APN Settings data entry + storage under 2.2
This is a discussion on Problem with APN Settings data entry + storage under 2.2 within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Oops, I thought the op could only not save apn's, missed that the op can't connect to the internet. Ken...
Results 11 to 16 of 16
Thread: Problem with APN Settings data entry + storage under 2.2
    Oops,
    Ken
    [SIGPIC][/SIGPIC]
    San Francisco Giants
    Junior Member Seumas's Avatar
    N1 loses APN settings ...
    I'm having the same issue ... would be interested in knowing if there's a fix ...
    Stock N1, Android 2.2
    Work-around for "empty APN list"
    I discovered that if you power-down the N1, and remove the battery for a while (about 30 seconds when I tried it last night), then re-start the phone, the APN list re-populates.
    This is a nuisance if this is going to happen often, although luckily it's only happened to me once thus far.
    Junior Member aguilera_reyes's Avatar
    HI DUDES!!!
    I think I found the solution (don't need to factory reset, flash or complex stuff like that)
    All this mess is becaused of a "wrong input" in the field "MNC"... if you search a little in Wikipedia, you will know that MMC and MNC identifies carriers around the world. The thing is that MNC is only 2 numbers (example 03, for Movistar here in México)... but you HAVE TO enter it using 3 digits (example: 030).
    This doesn't affect 3G functionality on the phone.
    Try it, use 3 digits in both MMC and MNC... then save as usual, your APN name will show up on the list.
    Hope this helps ñ_ñ
    Junior Member saad.thiab's Avatar
    hi
    i used to suffer from this problem,only yesterday iculd solve it.
    1. download "apn manager" from android market
    2. open "apn manager" go to "insert apn"option
    3. fill in your network apn information
    4. klick the save button below
    5. thank god when it works
    Junior Member wany's Avatar
    Jun 2011
    if you used market access g0 to custom and enter you network code
    MCC AND MNC
    you can get it from that link
    Number Portability Lookup | Realtime Carrier Lookup | HLR Lookup
    and restart your device power off it will be work
    Thanks
android 2.2 apn fix
android 2.2 apn save problem
apn disappeared htc glacier
apn save problem android 2.2
apn setting for my android 2.2.4 tablet
cannot save apn on my tablet
citadel android data entry problems
disappearing apn fix android
galaxy nexus wont hold apn settings
koodo galaxy nexus s mmc and mnc
loss of apn settings in droid incredible 2.2
my apn settings wont save
rooted apn settings disappearing save
storage/data/apn
why apn settings disappearing from tablet
