Please Please Help with OTA updated problem
This is a discussion on Please Please Help with OTA updated problem within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; OTA FRF91 will not install HELP !!!!!! I have a T mobile Nexus One running FRF72 which i installed manually with no problem. Now whenever ...
Thread: Please Please Help with OTA updated problem
    Junior Member nawlins411's Avatar
    I have a T mobile Nexus One running FRF72 which i installed manually with no problem. Now whenever i turn it off I get a notice that updates are availble . When I click install now it goes thru the process than I get an Error messages that says E:No signature found E: update aborted .My phone works great and I love FRF72 ,but would like the full upgrade please help
    Quote Originally Posted by nawlins411 View Post
    I will copy a post that I made on another thread that you made... If it will not update via OTA, try doing it manually. It's very simple and easy to do. Here is the location of that thread : http://www.nexusoneforum.net/forum/n...tall-help.html
    Directions:
    Try doing it manually.
    Go here http://android.clients.google.com/pa...B.db99fdf1.zip and download the update. Save it at UPDATE.ZIP and NOT update.zip.zip.
    -Put the newly renamed file on the root of your SD CARD
    -Power off the Nexus One
    -Hold the “volume down” key and press the power button
    -When phone restarts scroll down to “recovery” and press the power button
    -When a triangle with exclamation point appears, simultaneously press the power and volume up buttons
    -Select 'Apply sdcard:update.zip' from the menu
    -Once the update file is installed, select the option to reset your handset.
    Yeah still getting the same error message when i try the manual method .
