Download speed slower than upload
This is a discussion on Download speed slower than upload within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Not sure if this belongs here, but my download speed is significantly slower than the upload speed. I don't know whether this is the working ...
Thread: Download speed slower than upload
    Junior Member kvon's Avatar
    Not sure if this belongs here, but my download speed is significantly slower than the upload speed. I don't know whether this is the working of my network (T-Mobile) or whether it could be a hardware issue.
    To give you an example, here is a short list of my speeds on the local 3G:
    Down / Up (kbps):
    609 / 1129
    667 / 1035
    On wifi at home I got:
    5453 / 796
    The last result leads me to believe it is a network issue. Should I contact T-Mobile?
    Thank you!
    Senior Member vinny's Avatar
    Could be getting your area set up for the HSPA+ network. My upload speeds were crazy before my area went HSPA+. Good Luck. Could also be just working on your towers. Change the server on your speed test app and see if it changes. I bet just working on your network towers n your area.
android download slower than upload
android tablet download speed is slower than upload speed
android tablet wifi download speed is slower than upload speed
android wifi download slower than upload
download speed slower than upload speed on android
