Say 'mobile network not availible' with signal ???
This is a discussion on Say 'mobile network not availible' with signal ??? within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; when i try to make a call on my nexus one it says mobile network not availible even though the phone has signal and it ...
Thread: Say 'mobile network not availible' with signal ???
    Member mattwallis's Avatar
    when i try to make a call on my nexus one it says mobile network not availible even though the phone has signal and it was working fine before.
    im on vodafone uk. any ideas people ???
    i cannot send messages or recieve them and calls
    ps. it says emergency calls only instead of vodafone uk even though the signal is on full.
    Banned azzman's Avatar
    try this.
    *#*#4636#*#* in the phone area.
    and you will see a new screen.
    select PHONE INFORMATION
    then scroll all the way down, and select WCDMA preferred (select WCDMA if 3G is good in your area and it wont switch back and forth on you anymore), and then hit home and it will cycle the radio.
    i have read on the vodafone forums that bicester site is currently down where i live so thats the problem. but does this help with getting your signal better ?
    this will stop you from going from 3g to edge all the time. so if you solid 3g in your area, i would go wcdma only and it will connect to the 3g network and stop looking for the edge network.
    In my area, i live in washington dc and it sometimes goes in and out when i go from upstairs to downstairs, so with this trick it stays on 3g all the time.
    hope that answers your question.
    Junior Member 1hen2ducks's Avatar
    On a GSM phone like AT&T you need to select GSM only.
cricket mobile network not available
cricket phone says mobile network not available
mobile network not available cricket
mobile network not available samsung
mobile network not available vodafone
mobile network not found full signal
nexus one mobile network not available
selected network vodafone uk unavailable
selected network vodafone unavailable
vodafone mobile network not available
vodafone mobile network.not found
vodafone network not available
vodafone network unavailable
why is network unavailable cricket
