Question about GPS
This is a discussion on Question about GPS within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hello, I have a question about the GPS in the Nexus One. First question : How can you use the GPS ? U need to ...
Results 1 to 10 of 11
Thread: Question about GPS
    Junior Member Flandern's Avatar
    Question about GPS
    Hello,
    First question : How can you use the GPS ? U need to drive before he speaks or how it just works ?
    Second question : Do you need Internet Connection for the GPS ?
    Or how it works ?
    Thanks for the help
    (Srry for mine bad English)
    Greetings
    Senior Member rioja's Avatar
    Hi Flandern, welcome to the N1 forum
    You don't have to be driving for GPS it to work, I've used it walking around.
    Yes, you need to have a data connection to use GPS.
    Junior Member bcjack's Avatar
    I think it would be good to point out that you don't need data connection to use GPS as long as you have downloaded offline maps with apps like maverick/mapdroyd. The Navigation app that came with the phone for directions will need a data connection. I have yet to find an app that can calculate route direction offline. any clue?
    You need to first turn ON the GPS from the power control widget on the homescreen. Opening Google Maps will use your data plan to download maps as your location changes. Google Maps will automatically detect if the GPS is on and therefore use it to pinpoint your location.
    Usually it's best to be outdoors for the GPS to communicate effectively with the satellites to locate you easily.
    Once Google Maps detected your location (after hitting Options button and selecting My Location) you can then use the app to give you precise directions to where you want to go.
    Ok guys
    Very thanks for the answers.
    I'm testing it now and it works.
    But can you maybe chance the voice ? or not ?
    Junior Member andyandy989898's Avatar
    Co pilot works completely offline. Costs about 20 though
    Quote Originally Posted by andyandy989898 View Post
    Is there any free ?
    And 1 where u can use GPS ?
    I have Mapydroyd now but I can't navigate ?
    There are no free ones to be honest. Co pilot is very good, its like getting one of the cheaper sat navs on the market for half the price.
    Navigon is porting their Mobile Navigator 7 to Android. There is a 30 day trial version available in Europe (not the US yet). I believe that it's really a beta release at this point.
    The iPhone version of this application was one of the best selling programs in the iTunes store for a while. It's not cheap (around $70US), but it is very good.
    I think that if they dropped the price a bit, it would be a big seller on the Android Market.
    And where u can buy that ? Just in the Market app ?
