No automatic Bluetooth connection
This is a discussion on No automatic Bluetooth connection within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; On my newer nexus one, Im having a problem with the bluetooth not automaticly connecting when around my sony/ericson bluetooth headset. There both paired, and ...
Thread: No automatic Bluetooth connection
    Member CentralWARMK's Avatar
    There both paired, and I can manual connect it in settings, but I didnt have to do that in my first nexus one. With bluetooth on before, it would just automaticly connect to headset. But with the newer Nexus one is does not. Ive tried re pairing to the phone, but still no auto connect.
    It seems as though whenever my headset and phone are too far apart, I lose connection, and when there within the required distance, it will not automaticly reconnect, unless of course I do it manually.
    Of course if I turn bluetooth off on phone, and then back on, it connects.
    My first nexusone in january, I did not have to do that.
    What am I missing? Anyone else have a problem?
    You're not alone. It could have changed with Froyo. My bluetooth sometimes connects by itself and sometimes it doesn't, I never really gave it much thought.
    This is a long shot for your problem, but solved mine on auto connecting.
    Long press on your bluetooth device under bluetooth settings, then select unpair. Now reboot your phone then repair.
    Hope it helps, it worked for me.
    Ken
    [SIGPIC][/SIGPIC]
    San Francisco Giants
android bluetooth automatic connect
android prevent automatic bluetooth connection
android prevent bluetooth auto establish of connection
bluetooth headset auto connect
droid razr auto connect earpiece
galaxy 4 bluetooth headset auto connect
galaxy s4 bluetooth requires manual connection to my headset
htc mytouch 4g bluetooth not pairing issues
i30 bluetooth automatic connectivity issues
nexus 4 auto connect bluetoth
nexus 4 automatic bluetooth connection
nexus 4 bluetooth auto connect
ouya auopilot prevents bluetooth pairing
samsung galaxy 3 bluetooth where is the auto connect settings
