strange beeping noise when phone turned on
This is a discussion on strange beeping noise when phone turned on within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; when i'm starting up the phone lately i'll get this weird loud beeping sound with 5 or 6 beeps in a row. no idea why ...
Thread: strange beeping noise when phone turned on
    Member Rocco D'Voe's Avatar
    no idea why its happening or when it started, i can't find any settings that i can change to stop it.
    anyone know what this is?
    62 times
    Alien abduction warning in Da Couv! ? No idea...is it a tone associated with anything you've set?
    Senior Member Nobby's Avatar
    I used to get this when the notification sound was located on the sd card, when the device starts it checks the card but cant use the sound and so uses some sort of missing file noise. try setting your notification sound to a default android one and restarting?
    NEXUS ONE
    11.02.2010 - SuperBoot Rooted
    NOTION INK ADAM
    02.05.2011 - BEAST 2.2
    Quote Originally Posted by Nobby View Post
    thanks that was it! i changed the notification sound to a stock one and no more loud beeping.
    Yer it gets really annoying but only after adding a lot of new data to the card do I notice it takes longer to scan the card and so gives you the "checking" notification but cannot load your ringtone ad its on the SD card and locked so you get the default "missing file" tone. Glad it helped
    NEXUS ONE
    NOTION INK ADAM
android phone beeping
android phone keeps beeping
android restart beeping sound
beeps when turned on andrid
htc phone fain beeping
my phone is making a funny beep sound when i unlock it
my phone start beeping while i was using net
samsung s4 weird beeping
samsung s6 making strange beeping.
wh does android keep beeping
why does my android phone beep when i am using my ear
why does my phone beep when i turn it on
why does my phone keep making a loud beeping noise
why does my phone make a noise when i turn it on
why is my htc mobile making a bipping noise
