Bluetooth paired but not connected - and won't!
This is a discussion on Bluetooth paired but not connected - and won't! within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; My husband just bought a Samsung Vibrant (and is it a beauty!), and we tried to pair up via bluetooth as we had with his ...
Thread: Bluetooth paired but not connected - and won't!
    Junior Member tiaza's Avatar
    My husband just bought a Samsung Vibrant (and is it a beauty!), and we tried to pair up via bluetooth as we had with his old G1 (which someone stole, may it burn your ear). The Vibrant is also an Android, and the pair up process was simple. The problem is that although both phones show the other's status as "paired but not connected", neither phone offers the option to actually connect. When I long-press his device (sounds racy, eh?), the only option I am offered is to unpair. Any suggestions?
    Not sure about those phones but a short-press should connect on the N1. Works for me if my BT headset doesn't connect (but is paired).
    Junior Member edszr's Avatar
    Hi Tiaza...Just curious if you ever figured this out? I also have a Vibrant and can''t get beyond "Paired but not connected" when trying to connect to a bluetooth device.
    thanks,
    Ed
    Go into bluetooth and unpair device by long pressing on it. Reboot phone or pull battery. Don't just pwr off/on. Then repair. Worked for me.
    You could also try going into settings/apps/all and select Bluetooth Share and clear data after unpairing and before reboot.
    [SIGPIC][/SIGPIC]
    San Francisco Giants
    Yes and no. I did the hard reset that Rugman suggests - power phone off & pull the battery for ~30 seconds - and when i rebooted it, it connected just fine to my headset and laptop again, but it still won't connect to - bad news for you? - my husband's Samsung Galaxy Vibrant!
    I also used the Bump ap with him previously; it doesn't require a BT connection, but we can't get the phones to "see" each other. Annoying. I'm more geekish than my better half so i'll have to doink around with his phone and see what odd setting got toggled or whatever.
    best of luck to you. If I figure it out, i'll post.
    - tiaza
    Oh, I've also seen the advice to long press the device it's paired but not connected to. It doesn't offer the option to pair with this device. All it offers to do is unpair it.
android galaxy wont pair with windows rt
bluetooth won't stay connected to windows mobile phone
bluetooth wont stay connected to my samsung phone
connected but not working plt bbfit
galaxy s5 paired but not connected
microsoft band 2 won't pair
microsoft band does not stay connected android
microsoft band paired but not connected
note 4 paired but wont connect
why is my microsoft band paired to my phone, but not connected?
why won't bluetooth stay connected
why won't my bluetooth stay connected
why won't my windows phone pair up with my pioneer radio
why won't the blue tooth on my android phone stay connected
why wont my samsung galaxy s5 stay conected through bluetooth to my surface pro 3
