Help: Nexus one will not power on
This is a discussion on Help: Nexus one will not power on within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Originally Posted by AndroidIsTheTruth Possibly your screen went out. See if you can boot into recovery. Hold down the trackball and it the power button. ...
Results 11 to 20 of 44
Thread: Help: Nexus one will not power on
    Junior Member netzwerghh's Avatar
    Quote Originally Posted by AndroidIsTheTruth View Post
    Possibly your screen went out. See if you can boot into recovery. Hold down the trackball and it the power button. It sounds like more like a screen issue than battery issue IMO.
    Thanks four your reply. I already tried this and other things. You can read what I tried in this thread: http://www.nexusoneforum.net/forum/n...ck-screen.html.
    Interesting is that I read somewhere if the charging-indicator works this means the bootloader software _should_ work. But I'm unable to do trackball+power, volume- + power and even connecting the phone by usb to my notebook and running adb.exe does not work.
    Screen is completely black only charging-indicator is working proberly.
    Junior Member nexus3's Avatar
    hi every one
    could u fix this problem? i have used nexus1 for 7 month and it worked fine,just 3 weeks ago in KLCC i tried to push unlock button to call a friend,since that time until now my phone iz dead
    and no warranty
    Senior Member judeeg's Avatar
    Have you tried "Power button,volume button and track ball" press them all at once and hold till it comes on. Usually about 10 seconds or less. Keep us posted.
    [SIGPIC][/SIGPIC]Google Nexus One Froyo
    Rooted ~ CM 6RC3~ CM6.0 N1~ Nightlies ~
    Was Using~ eViL's NXSense v.1.21.3 - 720p, BT, FM, Hotspots, Kitchen Sink
    Was Using~ MicroMod's 2.12 Desire SuperHybrid
    Was Using~ MicroMod's Gingerbread CM7 Custom ROM v1.2 (DT's-Ap2Ext,Bat%,Themed
    Was Using ~ BlackDroid's Nexus One - UD 3.1.0Rom
    Was Using ~ CM 7 Gingerbread Green or Blue ExtremeMod ROM
    Now ~ CM NIGHTLY'S
    Try what judee said without the phone plugged in. Unless I missed something, you are doing these steps with the ac adapter plugged in.
    Could be a bad pwr button, but you say the green light goes off when you press pwr mmm?
    [SIGPIC][/SIGPIC]
    San Francisco Giants
    Quote Originally Posted by nexus3 View Post
    hi every one
    and no warranty
    nexus3,
    You kinda hijacked this thread, but we will try to help.
    Unlike the OP you haven't provided enough info to help. What all have you done exactly to start phone. Are you rooted. Any new apps installed recently. etc.
    [SIGPIC][/SIGPIC]
    Maybe we better stop flashing roms and wearing out our pwr buttons. I just had tp pull my batt and re pwr on. Trackball nor pwr button would work. Hope not an Omen.
    Aseems will be on our butts about this.
    [SIGPIC][/SIGPIC]
    Quote Originally Posted by rugmankc View Post
    Ut Oh! OK, I quit, at least till eVil gets the HD or Z with the camera and video. Then I will be happy. Really...Honest.... lol
    Hope you got it all working now Ken?
    Now ~ CM NIGHTLY'S
    All OK Judee,
    We work em hard, and if they break I get my new Android 2gz, HD, and dual cameras!
    [SIGPIC][/SIGPIC]
    yeah i did root my phone about 7 month ago
    but i didnt install any program out of market,
    i tried Power button+volume (up and down both) and trackball
    still dead
    any information that may help u ask me
    Junior Member gwassef's Avatar
    i got this issue with my mobile when i just bought it and opened it, it did not want to power one and each time i press the power buttom the charging led goes on green and orange, and does not work on, but when i pressed the volume buttom (do not remember the up or down one) it boots with the recovery screen. then i erased the memory and the device worked very nice after that. Hope this will be helpful to you.
google nexus 4 will not power up
google nexus not powering up
google nexus phone does not power up
google nexus will not power on
htc google nexus one does not start
htc google nexus one not turning on
my htc nexus one wont turn on
my nexus one wont turn on
nexus 4 not powering on
nexus 4 will not power on
nexus 7 not powering up
nexus 7 will not power up
