Help: Nexus one will not power on
This is a discussion on Help: Nexus one will not power on within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Can you boot into recovery or bootloader? Sent from my Nexus One using Tapatalk...
Page 5 of 5 FirstFirst ... 345
Results 41 to 44 of 44
Thread: Help: Nexus one will not power on
  1. #41
  2. #42
    Junior Member cucuko's Avatar
    re
    No, i can no enter in booter mod
  3. #43
    Junior Member stanefr's Avatar
    Apr 2011
    noderator ,thnk you!!!
    i curentlly updated to rc4 and my phone got crazy as the follow post.
    your answer powerd up my phone back .i just wantd to say thank you ,for 2 days im busting my head with this issue.
  4. #44
    Junior Member mateuscb's Avatar
    Jun 2012
    Solution to power on Nexus One with broken button
    Quote Originally Posted by osnus View Post
    Hi,
    I am very happpy with my nexus one until yesterday...I just installed trekbuddy and was loading maps on it. After that I played robot defender with it for almost an hour. I then I attached the phone to my computer for it to charge before sleeping. When i woke up, i pressed the power button but the phone is not responding. I removed the battery and put it back again and pressed the power button. I tried several times and at one point, I felt it vibrate 3x but still did not boot. Up to now i cant get it to work. When i attached it to the charger, the charging orange light is on until it became green indicating its fully charged. When i removed the battery while attached to the charger, it blinks green and orange and becomes a little warm. I tired several times the battery pull-out method to no avail. I dont have a warranty. Kindly help please...
    Charles L.
    I had the exact same problem. When connected, the green light comes on but can not turn it on using the power button or any combination of track and volume button. Thanks to this link, I was able to get it working: Manage a Nexus One with Broken Power Button [Updated]AndroidGuys.
    The solution is near the bottom (what an unbelievable solution):
    "The trick is to connect the phone via USB to a power source (a charger or computer) and then to remove and insert the battery successively, after a while (5-10 insertions) the device will get confuse and will start. This tip came from Karno, a user from the Nexus One Help forum"
    It may seem obvious, but the timing in which it is done is very important. [ame=http://youtu.be/SIkQtTJP_eo]Turn on Nexus One with broken power button - YouTube[/ame]
google nexus 4 will not power up
google nexus not powering up
google nexus phone does not power up
google nexus will not power on
htc google nexus one does not start
htc google nexus one not turning on
my htc nexus one wont turn on
my nexus one wont turn on
nexus 4 not powering on
nexus 4 will not power on
nexus 7 not powering up
nexus 7 will not power up
