pattern lock froyo
This is a discussion on pattern lock froyo within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi, when you set up a pattern lock on froyo, the only way I can find to disable it, is to remove it totally, then ...
Thread: pattern lock froyo
    Junior Member shed64's Avatar
    pattern lock froyo
    Hi, when you set up a pattern lock on froyo, the only way I can find to disable it, is to remove it totally, then when you want to use it again you have to start from scratch. Is there anyway round this? Before froyo I used an app to switch it on and off when necessary, but cant seem to do this anymore.
    UK
    8 times
    Nd1razor
    You can try No Lock,
    you can make a widget on your screen, tap to enable or disable the lock screen, if disabled, completely ignores all locks, and wakes the phone when any key is pressed.
    Thanks for that, seems to have done the trick.
    UK
    8 times
    Nd1razor
    no problem
nexus s remove lock pattern
