LED blinks red from time to time
This is a discussion on LED blinks red from time to time within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; From time to time the track ball led of my Nexus One running Froyo intermittently slowly blinks red. I do not have an app installed ...
Thread: LED blinks red from time to time
    Junior Member iamroddo's Avatar
    From time to time the track ball led of my Nexus One running Froyo intermittently slowly blinks red. I do not have an app installed which modifies the led colour so a missed call or an email causes it to blink white. This red blinking doesn't seem to be trigger by low battery or memory. I'm curious as to the cause, any ideas?
    low battery indication
    As I said in the initial query, it doesn't seem to be triggered by low battery.
    Check the Battery.. Charging issue?
    The battery charges just fine and doesn't discharge too quickly.
    Junior Member Lostviking's Avatar
    OK, you said "seems". What battery level? What level is the notification set for? Does it EVER do it with a fully charged battery?
    You need to provide some details if anyone is going to be able to help you.
    Sometimes when to blinks red it is connected and charging, sometimes it blinks when it has very recently finished charging ie that the LED at the top left of the front has changed from red to green.
