Nexus one problem??? Help!!!
This is a discussion on Nexus one problem??? Help!!! within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Had the phone for few days and a problem when i clicked for example the "MESSANGING" on my home screen it lead to aim screen ...
Thread: Nexus one problem??? Help!!!
    Junior Member livinlife's Avatar
    Had the phone for few days and a problem when i clicked for example the "MESSANGING" on my home screen it lead to aim screen to i click back it went to another app then i lcicked home i went home and clicked messanging again and it went to another screen of a app why isnt it go to messagning? it works now but it did that twice!!!! it froze everytime i tryed to quickly share a photo via facebook it froze one time there.
    The screen of the Nexus One is known to play tricks on you sometimes. When that happens, just turn off the screen then turn it back on. That should solve it.
    I hope that was usefull.
    well a new problem happened..... i locked it the nwhen i lciked the power to unlock no puzzle unlock wasnt there it was just my backround.. then i keep lockign and unlockign no puzzle i shut the phone off and restated?
    Junior Member nzalstar's Avatar
    What happens when you restart it is screenlock active?
    Have you checked to see if screenlock is turned off.. settings/location & security/screenlock.
    yea i checked becasue when i restarted the phone, it waas back?
    Maybe a factory reset might help. Did you try that?
