Mobile Stuck at bootup screen
This is a discussion on Mobile Stuck at bootup screen within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Phone stuck at bootup screen. After switching the phone on. Nexus X apears and keep reappering, noting else heappens. Cannot swich off the phone, unless ...
Results 1 to 9 of 9
Thread: Mobile Stuck at bootup screen
    Member wamchu's Avatar
    Phone stuck at bootup screen. After switching the phone on. Nexus X apears and keep reappering, noting else heappens. Cannot swich off the phone, unless battery is removed. Anyone know what is the problem.
    Quote Originally Posted by wamchu View Post
    Try a Hard Reset
    http://www.nexusoneforum.net/forum/n....html#post4316
    Hope you did not the battery pull while updating your OS...
    Try a Hard Reset
    Hard reset dose not work. I did not take battery out while updating OS
    Android Jr Member gonzo13's Avatar
    mine did that the day it arrived; just kept rebooting.
    i had to send it back to HTC and they gave me a replacement.
    We need more info:
    Build?
    Rooted?
    What recovery?
    If rooted and you did a backup you can pull battery and before it powers up hold down vol- (down) and pwr button at same time for a few seconds. That will get you to recovery. Then you can flash your backup, wipe first. If you got it and all works well you can do another backup.
    Ken
    [SIGPIC][/SIGPIC]
    San Francisco Giants
    it got android 2.2. its never been rooted with orignal build. So the problem happens suddenly.
    Member Mastermrz's Avatar
    Wow! Wait, does your phone go to the :nexusx: and then goes blank? If yes, your experiencing the same problem i did. Now, did you, for example, install an app on the market and then this problem happened? Or how did it happen.
    For me, i installed a app that was actually ment for another phone and boom, phone only came to the :nexusx: and went blank and my phone was ROOTED as in the Bootloader was unlocked but i still had Froyo 2.2
    Since the app caused the problem and had nothing to do with rooting my phone, HTC repaired it for free which amazed me! =D
    Your best bet is to send it to HTC for repair and since you didnt root your phone, your 100% sure the repair is free
    Sent to HTC. Let see what happens.
    They will repair, if its a problem in the Software, its covered under warrenty. Even my phone was rooted and unlocked and they covered it free of charge! =D
nexus 1 stuck on x screen
nexus one stuck on x
nexus s frozen at start up
