Can't access network. Please help.
This is a discussion on Can't access network. Please help. within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi guys, I usually read this forum when I have problems, but now I need to actually describe what's happening to see if someone can ...
Thread: Can't access network. Please help.
    Junior Member tantundem's Avatar
    Hi guys,
    I usually read this forum when I have problems, but now I need to actually describe what's happening to see if someone can help me out.
    I bought a Nexus One from the US, whilst in the UK. It worked perfectly in the UK.
    Now I'm in Brazil with a local Sim card. It worked fine for 3 weeks and now, for the past couple of days, it has been acting weird. It doesn't locate the network so I can't make or receive calls, nor access the 3G.
    If I turn it off and remove the Sim card, sometimes it works again when I turn it back on. Not always.
    There's a small Sim card + exclamation point on the notification panel. And although the antenna bars are there, there's an 'Emergency calls only' notification as well.
    If I try to make a call it will state 'Mobile network not available'.
    Now, I've searched everywhere for a clue as to why this is happening without any luck. Can anyone help me?
    62 times
    Sounds like a faulty SIM...go get a new one.
mobile network not available
sim card with exclamation point#gsc.tab
