Handcent Auto Correct issues
This is a discussion on Handcent Auto Correct issues within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi Since upgrade Froyo handcent has become a pain in that it auto corrects words without my wishing to do so. Does anyone please know ...
Thread: Handcent Auto Correct issues
    Junior Member stamina_josh's Avatar
    Hi
    Since upgrade Froyo handcent has become a pain in that it auto corrects words without my wishing to do so. Does anyone please know how to turn this off? Under the handcent "application settings" there is "Auto Text Settings". Under here is the option "Auto Text". Checking the box will turn off auto text correction.
    Problem is, you cannot select this setting. Any ideas why?
    thanks
    I'm not sure but you might want to try going to settings, language and keyboard, Android keyboard settings (assuming you're only running the stock one) and at the bottom there is a selection to do with auto fixing. See if that has any effect on handcent, or on the ability to select its autocorrect.
    I never noticed that in handcent before, that the option is unselectable. Might be worth emailing the dev.
    Thanks you are a genius, this fixed the issue. The actual autocorrect is being done at the froyo level, not the handcent level. Adjusting this under settings -> language and keyboard, worked a treat.
handcent autocorrect
handcent autotext not working
handcent disable autocorrect
handcent sms auto correct
handcent sms autocorrect
handcent sms turn off autocorrect
handcent turn off autocorrect
how to disable autocorrect on handcent
how to turn off autocorrect on handcent
how to turn off spell check on handcent
how to turn on autocorrect on handcent
turn off autocorrect handcent
turn off autocorrect handcent sms
turn off hand scent auto correct
