No track ball settings
This is a discussion on No track ball settings within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I use NoLock for the trackball wake before I upgraded to CM6, but found that I like it better than the CM6 version as I ...
Results 11 to 12 of 12
Thread: No track ball settings
    I use NoLock for the trackball wake before I upgraded to CM6, but found that I like it better than the CM6 version as I can also use the volume up/down to wake the phone too, and don't have to press the trackball twice as I do with CM6. Some programs, like handcent will let you choose colors for the trackball with 2.2.:nexusx:
    Senior Member coldfusionb's Avatar
    Before CM6 I use swithpro for trackball wake-up and handcent for colors. You can set different colors for different people on handcent for your trackball.
    One Nexus To Rule Them All!
android trackball config
trackball settings nexus one
