Stuck in Safe Mode
This is a discussion on Stuck in Safe Mode within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Originally Posted by Aerosavant I don't believe it. Just done a factory reset and it's still stuck in safe mode. What to do now???????????? And ...
Results 11 to 20 of 21
Thread: Stuck in Safe Mode
    14 times
    Quote Originally Posted by Aerosavant View Post
    And it's wiped all of my contacts. I am so F****ing angry
    I'm sorry to hear that.
    Did you try holding the trackball before booting up?
    Its hard to find info on this safe mode. I never even knew it existed until you came along.
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    Android Lurker maris's Avatar
    I found this in a search, hope it helps:
    Turn the phone off, then hold down Power button and Menu while it boots. That should remove it from Safe Mode
    Senior Member f0ul99's Avatar
    Wow! We have safe mode? :D
    But hopefully there will be no 'blue screen of death'
    Light-sabred from my NeXuS One using Tapatalk
    Junior Member Aerosavant's Avatar
    I've tried all the suggestions to try and get out of safe mode to no avail.
    Guess it means a visit to the Vodafone shop, see if they can fix it (not holding my breath).
    14 times
    That is unfortunate. Have you contacted HTC support?
    [PHONE] Nexus 4
    [TABLET] Nexus 7
    It should restore your contacts if you sync with your google account once you startup again.
    Finally got fed up trying to get it out of Safe Mode, tried all the hints and tips to no avail.
    Went to Vodafone and they like just about everybody else hadn't even heard of Safe Mode. They're sending it back for repair so now I'm without my Nexus for at least 10-14 days.
    Member Batman's Avatar
    Safe mode?
    Interesting.
    This is your life, and it's ending one minute at a time.
    Junior Member tRodHxC's Avatar
    Question Same thing with my extra N1 is happening.
    I can even flash custom ROMs, radios, and even Clockwork and AmonRA Recoveries. Ive pretty much done everything, including hard reset. To bad I dont have my original NAND backup. Maybe if I flash it back to the Stock OS it will take it out of safe mode. Anyone heard any new fixes?
    Would anyone attach a pic of this Safe Mode? I am curious.
    InViSiBLe-cHoKe by TaPaTaLk
andriod stuck in safe mode
android phone stuck in safe mode
android safe search stuck
android stuck in safe mode
android table stuck in safe mode
android tablet stuck in safe mode
disable safe mode android
dna stuck in safe mode
how to disable safe mode on nexus s
how to exit safe mode nexus s
how to turn off safe mode in samsung nexus s
htc droid dna stuck in safe mode
nexus s safe mode exit
samsung tablet stuck in safe mode
tablet still in safe mode after factory reset
