Stuck in Safe Mode
This is a discussion on Stuck in Safe Mode within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Earlier this week, I had problems with my Nexus One,, screen freezes etc. I believe it occurred after I allowed a few App upgrades - ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Stuck in Safe Mode
    Junior Member Aerosavant's Avatar
    Stuck in Safe Mode
    I believe it occurred after I allowed a few App upgrades - Google Earth, Spotify and one other I can't recall.
    I wasn't able to switch off as the screen was unresponsive.
    As I was trying to get it to respond it changed to a white screen with some very very small text down the left hand side.
    I managed to highlight one of the instructions, Reboot I think. Not much happened that I could see.
    I removed the battery then reinserted.
    It powered up but has remained stuck in Safe Mode
    I have since rmoved all apps that I don't need but despite switching off and removing the battery countless times it won't come out of Safe Mode.
    Any ideas anyone??????
    14 times
    Safe mode? Never heard of safe mode on an android phone. You were able to remove apps in this safe mode? Please elaborate
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    In Safe Mode it shows all 5 screens in the normal way with all the Apps displayed and fuctional. However when I press the middle Apps button (the one with the 4 squares x 4 squares) on the tool bar it only shows the default apps supplied with the phone.
    Yes it allowed me to delete apps through my uninstaller app and just tried it, it allows me to install apps. But of course i can't place them on a screen because they don't appear on the Apps list??????????
    14 times
    Are you using a launcher? Adw or LP?
    [PHONE] Nexus 4
    [TABLET] Nexus 7
    So please tell me why at the bottom left corner of my screen there is a small black rectangle with Safe Mode in white text.
    Haven't got a clue what Adw or Lp is??
    If you look in this thread
    http://www.nexusoneforum.net/forum/nexus-one-tech-issues-bug-reports/8324-help-nexus-one-will-not-power.html
    Post 5:- N1David mentions Safe Mode
    The link you provided did not work for me. But I found it anyways.
    http://www.nexusoneforum.net/forum/n...not-power.html
    Did you try to do a factory reset?
    Come here little sheep; I have a nice juicy apple for you!
    [SIGPIC][/SIGPIC]
    Nexus One: Locked and Rooted
    ROM: CM7
    14 times
    Quote Originally Posted by Aerosavant View Post
    Well I'll be damned....I guess you learn something new everyday.
    Are you able to do a factory reset in the Recovery options?
    [PHONE] Nexus 4
    [TABLET] Nexus 7
    Could probably do a factory reset but don't want to go through the pain of re-doing all my email accounts etc
    14 times
    You could try holding the trackball when you startup after the nexus x appears. If that doesn't work, a factory reset might be your only option.
    [PHONE] Nexus 4
    [TABLET] Nexus 7
    I don't believe it. Just done a factory reset and it's still stuck in safe mode.
    What to do now????????????
    And it's wiped all of my contacts. I am so F****ing angry
andriod stuck in safe mode
android phone stuck in safe mode
android safe search stuck
android stuck in safe mode
android table stuck in safe mode
android tablet stuck in safe mode
disable safe mode android
dna stuck in safe mode
how to disable safe mode on nexus s
how to exit safe mode nexus s
how to turn off safe mode in samsung nexus s
htc droid dna stuck in safe mode
nexus s safe mode exit
samsung tablet stuck in safe mode
tablet still in safe mode after factory reset
