please help mewith my nexus one !
This is a discussion on please help mewith my nexus one ! within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; So he DL an app which possibly broke your phone and left the country? lol. You didn't bother to ask him as soon as he ...
Results 11 to 15 of 15
Thread: please help mewith my nexus one !
    Member Kits2GR's Avatar
    So he DL an app which possibly broke your phone and left the country? lol. You didn't bother to ask him as soon as he DL it? If you did a factory reset and its still like that, you prob going to have to call the Nexus One support line and possibly send it in for repair.
    Android Lurker maris's Avatar
    I found this link which may be helpful:
    Nexus One: Boot in Safe Mode
    I hope it works for you.
    Junior Member rdewa's Avatar
    Quote Originally Posted by Maris View Post
    No it didnt work also
    Try removing the SD card and the sim card from the phone and then booting up. Rule out as much as you can. Also, is the battery empty? plug it in if so.
    I'm trying to remember what options the stock recovery gives you. can you wipe any cache? perhaps try to factory reset again, what have you got to lose?
    Also, remember that on a factory reset it will take a while to boot up, so don't pull the battery when you try it again for at least ten minutes, just in case. You might want to let the battery charge for a while before attempting this again as well.
