Battery Issue?!!
This is a discussion on Battery Issue?!! within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Ok this has been a strange problem that has just surfaced for me. My battery life has been cut basically in half. I have two ...
Thread: Battery Issue?!!
    Junior Member Nevsky's Avatar
    Battery Issue?!!
    Ok this has been a strange problem that has just surfaced for me. My battery life has been cut basically in half. I have two different batteries that I keep fully charged and I'm having the same issues with both batteries so I no its not a bad battery. I have wiped the phone clean thinking it might have been something that I added. My phone is 2.2 has been flawless up until this. I would usually get more than a full day without having to charge. Another thing worth mentioning is that I have been turning off my phone at night to get a full charge and it never gets to a green light letting me know that it is fully charged???? When i turn on the phone it looks to be fully charged I just can't imagine why its not giving me a green light.
    I run 3g all day..no wifi on..no satellite on.
    UK
    8 times
    Nd1razor
    1. How do you care for your battery? Overly overcharging and depleting the battery can damage it.
    2. Are there any apps that you recently installed?
    3. Open up settings>about phone>battery usage and see whats nomming on your battery.
    -Fury
    Typically the biggest drain on my battery is display but that has always been the case. I have not changed and thing and all of the sudden this problem has started with both batteries.
