Can't connect to home WiFi
This is a discussion on Can't connect to home WiFi within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi Folks, Since I received my OTA Froyo update my N1 has never connected to my WiFi at home. I have done a few things: ...
Thread: Can't connect to home WiFi
    Junior Member martin.omahony's Avatar
    Angry Can't connect to home WiFi
    Hi Folks,
    1. Changed my pre-shared key to less characters, as originally this was the full available length (a little over the top I know)
    2. Changed my network encryption type between PSK and PSK2, I haven't tried WEP, but don't see why I should have to seeing as it's less secure and previously I was connected using PSK2
    3. Using TKIP & AES encryption or AES only
    4. Forgetting the network within WiFi settings
    5. Installed WiFi Fixer, which seems to make no difference
    6. Removing symbol characters from my pre-shared key (just in case this was an issue) such as # or ? etc
    I cannot even connect. Originally I was receiving an error that I was using the wrong password, even though I clearly wasn't.
    The status just says connecting then, disconnected.
    Any help would be appreciated, are others experiencing these issues?
    I'm a UK Vodafone N1 user
    Thanks,
    Martin
    Member SENTY's Avatar
    I have this problem and ive found other people mentioning it.
    I have 2 wifi networks and my nexus connects to one perfectly and the other it just cycles through connecting and disconnecting and in the settings list is says "disabled, wpa/wpa2 ..." in the network info. ive tried deleting it and re adding it and the other wifi network works perfectly.
    Member MrsMime's Avatar
    This happened to me last night. I went through all the steps you did before eventually just resetting my router, and it did the trick. Sometimes the simplest solution is the right one.
    These have some ideas,
    WIFI problem on Desire after Froyo upgrade - Android Help
    Help - Can't connect to my wifi network after Froyo update - Android Forums
    Since Froyo - WiFi N Problems @ Home - Droid Forum - Verizon Droid & the Motorola Droid Forum
    Also, since it worked once this is probably useless. But, on my Apple router I have to into settings and add my Mac Address to be allowed.
    [SIGPIC][/SIGPIC]
    San Francisco Giants
android cant contect to wep
android galaxy s4 can't connect to wifi
android tablet cannot connect to secure sites
can't connect to my wifi from my nexus
cant connect to wifi at home with galaxy s4
how to connect nexus one to wifi
i can`t hook irola tablet to my wifi in my home
i cant connect my nexusone to wifi
nexus 7 cannot connect to wep shared
nexus 7 cant connect to wifi
nexus one can't connect to wifi
nexus one not connecting to wifi
why cant i get wifi on my nexus s 4.1.1
why i cannot connect to wifi my htc nexus one
wifi wont connect mytouch 4g
