Nexus boot to X, RADIO_VZ Fail-PU
This is a discussion on Nexus boot to X, RADIO_VZ Fail-PU within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I have a Nexus that don't boot It is not rooted, it just have one month. I can't reset it, the screen with the androids ...
Thread: Nexus boot to X, RADIO_VZ Fail-PU
    Junior Member widam3d's Avatar
    I can't reset it, the screen with the androids in skate are corrupted, fastboot don't work.
    Also I try with epe45B y con el EPE76 and report RADIO_VZ Fail-PU
    and 8 SYSTEM Fail UZ
    Any suggestion and information will be greatly appreciated, I hope there is a solution.
    regards
    MR
    Senior Member f0ul99's Avatar
    Frankly now, I have no idea but may I know what did u do or install or flashed before it happened?
    Light-sabred from my NeXuS One using Tapatalk
    14 times
    Doesn't look to be rooted. Sounds like your unit might be defected. Have you contacted HTC?
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    Guess he sorted up everything then.
    It seems that has memory leaks, I try everything to flash a new rom, but it gets corrupted when it boots, screen has garbages. I guess i will have to send to htc to see if they can fix it.
    thx anyway..
    MR.
    Quote Originally Posted by widam3d View Post
    thx anyway..
    MR.
    Actually you cannot flash any rom unless you rooted. I agreed on Slim that most probably it was defected/ hardware problem or something and we have no clue to help since u gave little infos.
    Do send to HTC and if it all good later come back and tell us about it.
fail-pu nexus one
radio vz fail-pu
