landscape mode issues
This is a discussion on landscape mode issues within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; My N1 has stopped going into landscape mode as of today. Has anyone else had this issue and how do you fix it??...
Thread: landscape mode issues
    Junior Member phuzzykiller's Avatar
    Question landscape mode issues
    Feb 2012
    10 times
    landscape where? Need a little a more information. If the home screen what UI are you using? Is it in an app?
    Please supply a little more detail. Thanks.
    Androidfied.
    I'm using the android 2.2 standard UI. Any instance that landscape mode would apply (ie. using the keyboard), it does not flip over to when the phone is turned. It's starting to get very aggravating.
    Android Lurker maris's Avatar
    Maybe something messed with your settings? Check under Settings/Display settings and be sure Auto-rotate screen is checked.
    If that didn't work, try rebooting the phone.
    Feb 2012
    10 times
    If you auto rotate activated and it's not rotating, there's a possibility that something went wrong with your accelerometer.
    Androidfied.
landscape mode. unfortunately, has stopped
nexus landscape mode wallpaper issue
