Wifi stay connected after a long sleep? NO
This is a discussion on Wifi stay connected after a long sleep? NO within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I know some people may have discussed this issue but I haven't got an answer yet. Similar to others, my phone sleeps with Wifi on ...
Thread: Wifi stay connected after a long sleep? NO
    Member schizophrenia's Avatar
    Similar to others, my phone sleeps with Wifi on and after an hour or too, Wifi is disconnected when I woke the phone up. Note I have already set the Wifi sleep policy to "Never".
    So i went into the log and saw these:
    D/WifiService( 85): acquireWifiLockLocked: WifiLock{NetworkLocationProvider type=2 binder=android.os.Binder@44d91bc0}
    D/WifiService( 85): releaseWifiLockLocked: WifiLock{NetworkLocationProvider type=2 binder=android.os.Binder@44d91bc0}
    D/ConnectivityService( 85): ConnectivityChange for WIFI: DISCONNECTED/FAILED
    V/ConnectivityService( 85): Attempt to connect to WIFI failed.
    D/ConnectivityService( 85): Dropping ConnectivityChange for WIFI: DISCONNECTED/SCANNING
    D/ConnectivityService( 85): ConnectivityChange for WIFI: CONNECTING/CONNECTING
    D/ConnectivityService( 85): Dropping ConnectivityChange for WIFI: CONNECTING/AUTHENTICATING
    D/ConnectivityService( 85): Dropping ConnectivityChange for WIFI: CONNECTING/OBTAINING_IPADDR
    then it kept looping these, for so many times:
    are there any good samaritans who can help me with this piece?
    Junior Member djpaan's Avatar
    I am having the same problem as you do, but my trouble started when I've changed my wifi router. The settings were the same, the lease time is set to forever, but for some strange reason nexus won't stay connected...
    Try a different router (go to a coffee shop or to a friend's house) and test the loss of connectivity there.
    Regards, A
    Quote Originally Posted by djpaan View Post
    Regards, A
    thanks for the comment.
    actually i have been using the same route since last year and my Hero never had such problem.
    and it happened after I started using the N1 as a replacement.
    I dont even know how to fix such problem
    no one else has any comment on this?
    actually i asked my friend to try to same thing, let the phone sleep at home (he got also the iphone as main phone, ha) so he left his N1 at home on, and the phone stayed connected to wifi the whole time.
    so i tried to eliminate factors between his and mine.
    1. we both use the same router
    2. he uses STOCK home, I use Launcher Pro / Sweeter Home 2
    I am just wondering, if using Launcher Pro / Sweeter Home, which I found out both of these theme takes up quite a big deal of CPU usage (i am not sure) or RAM (i am sure, as they restart themselves sometimes and I checekd logcat and found out they restarted because of insufficient VM), would this be the problem of Wifi Cutting Off?
    please help?
android connected sleep
android how long until wifi sleeps
android sleeps wont' stay connected to wifi
wifilock bug
