N1 won't power on, blinking orange/green
This is a discussion on N1 won't power on, blinking orange/green within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hello, I've just got a hold of Nexus one phone that won't start at all. I found indicator blinking from orange to green repeatedly if: ...
Thread: N1 won't power on, blinking orange/green
    Junior Member venior's Avatar
    Exclamation N1 won't power on, blinking orange/green
    Hello,
    1. Battery is placed and power button pressed.
    2. Phone on charger.
    3. Phone on charger and battery in (w/o pressing the power button).
    I've tried manipulating battery/charging cable but in any way it wont start. Seeking on the web I found outdated topics that it can be either defective phone, either overheated (I doubt this one is - it doesn't getting warm at all while charging) or battery is dead.
    However it is hard for me to find HTC battery that will fit on N1 (HD2 won't).
    Please advice what can be the problem? Which model's battery will fit Nexus One?
    Thanks.
    You bought a phone without turning it on?
    Batteries should be available on legit sites, google.
    If it doesn't get arm at all that may it.
    Did you try holding down the vol- (down) button and power button at SAME time until it powers on. Should not take more than 10 seconds. That will put you into recovery and eliminate dead battery.
    [SIGPIC][/SIGPIC]
    San Francisco Giants
asus g750 power indicator blinking green orange
asus tranfomer oveeheatong blinking orange light
blinking orange light on nexus
green orange n1
green orange n1 recovery
gren orange blink nexus
htc nexus one blinking orange green
htc nexus one orange light
mytouch 4g blinking orange and green light
mytouch 4g charging orange light blinks but wont turn on
nexus 4 blink orange
nexus one flashes orange and green light
nexus one orange green flashing light
nexus one status light blinks green and orange
thunderbolt blinking orange and green
