Nexus One Pattern Lock + No Lock
This is a discussion on Nexus One Pattern Lock + No Lock within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hello Everyone, I was just wondering if its possible to use the app "No Lock" in conjunction with the Pattern Password on the Nexus One. ...
Thread: Nexus One Pattern Lock + No Lock
    Junior Member I3iach's Avatar
    Post Nexus One Pattern Lock + No Lock
    Hello Everyone,
    I was just wondering if its possible to use the app "No Lock" in conjunction with the Pattern Password on the Nexus One. So I was wondering if we could wake up the Nexus one with "No Lock" then unlock it with the Pattern password?
    Much Appreciated
    Metro Atlanta
    53 times
    I moved your post to a more appropriate section.
    Senior Member coldfusionb's Avatar
    I don't think you can I believe it's one or the other.
    One Nexus To Rule Them All!
    Ok Sweet. Thanks for the reply. Cheers
    Feb 2012
    10 times
    One or the other. The slide lock only works with Pin Number.
    Androidfied.
    UK
    8 times
    Nd1razor
    Widget locker allows you to use a lockscreen and wake with trackball, dnt work perfectly with me however
    Thanks for the heads up. Cheers
nolock on google nexus one
