Green Trackball Issue
This is a discussion on Green Trackball Issue within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; My Nexus One's trackball has been lit green for about 4 days now. I have no clue what the problem is or even if it ...
Thread: Green Trackball Issue
    Junior Member thastig's Avatar
    Unhappy Green Trackball Issue
    My Nexus One's trackball has been lit green for about 4 days now. I have no clue what the problem is or even if it is a problem since green is a color saying everything is ok.
    Anyways i was wondering if anyone had any clue what this means. I am using a rooted Nexus One with 2.2. I havent installed any application recently which would be able to explain this.
    Do you have any notifications in the top bar, like message or email etc?
    So you are rooted, but are running stock froyo? Or a custom ROM?
    I only have email and Task Killer app. I occasionally clear all unread messages and kill all background running apps. No dice
    Are you using a third party messaging app?
    If so, make sure that you disable notifications from the built in messaging app. Otherwise, they BOTH want to notify.
    I use handcent SMS app and the notifications are to blink with a blue LED for 5 seconds when a message is received. I wish i knew what this means. It's like the double rainbow all over again
    Quote Originally Posted by thastig View Post
    Well, like I said, make sure to turn OFF notifications from the built-in messaging application. Otherwise, it will blink green for you and won't stop when you attend to the message with Handcent.
    In other words, BOTH messaging applications will notify. Even when you respond with one or the other.
google nexus one green ball
google nexus one has a green light in track ball
green trackball nexus one
htc nexus green ball
htc nexus one trackbalk stays green
nexus green track ball light
nexus one green trackball
nexus one trackball stays on
nexus one trackball turned green
trackball going green in htc nexus
trackball on nexus one is on constantly moisture
