Nexus One won't charge via AC!
This is a discussion on Nexus One won't charge via AC! within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Ok well I've been on CM6 stable since it came out, with the kernel that comes with it. 2 nights ago I flashed pershoots latest, ...
Thread: Nexus One won't charge via AC!
    Junior Member 4GE's Avatar
    2 nights ago I flashed pershoots latest, 2.6.35.4 to try and fix my horrendous battery life... it worked well.
    I let it charge through the night through AC, all good. I wake up and the phone is still running by 5pm. At 5pm I was on about 30% and started to charge it again while using it. When it hit 50%, the LED just turns off and the phone wont recognize it being plugged in anymore. Pershoot recommends to unplug then plug it back in, which I obviously tried but no avail.
    I can charge through USB which is weird, but it's not as fast and I can't leave it plugged into my computer all night.
    Is it a software or hardware thing going?
    I went back to the CM6.0 default kernel and even the nightlies, but it still wouldn't charge.
    Any ideas before I throw it out the window ?
    14 times
    That is Strange.
    Did you make a Nandroid backup before flashing that pershoot kernel? if so you could try restoring that.
    or maybe its a problem your Charger Cable.
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    I haven't restored a nandroid before that, but I did just flash back to CM 6.0 which I was using fine for many weeks. I'll try restoring now.
    Where would I go about buying an OEM charger if the problem is the charger?
    The non-OEM ones on ebay for 2 dollars are crap and wouldn't trust them charging my phone.
    USB is really annoying...
  1. First Look at Sony Ericsson Xperia Arc
    Last Post: 01-17-2011, 05:23 PM
my nexus 7 wont charge with its oem charger
nexus 7 wont charge on ac
nexus one won't charge
