Internet problem with my phone
This is a discussion on Internet problem with my phone within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; ok i will try that, i bought the phone from a website that sold the phone, it was imported from America...
Results 11 to 20 of 25
Thread: Internet problem with my phone
    Junior Member Oreex0's Avatar
    Junior Member fvzuben's Avatar
    same problem
    I Think i have the same problem, WiFi just show error message.
    Tried diferent browser, manual intall of update, pull battery off, airplane mode on off, tried everything. WiFi keeps showing error message, the 3G is working fine and so is the BT. My APN are correctly set and I don't know what to do....
    I have a Nexus One with the last update from september 24th.
    I only got The Mobile internet problem but it's fixed now emailed the htc Swedish support and they fixed the problem in a day
    Oreex0, What did they do?
    fvzuben,
    Try: menu/settings/wireless and networks/wifi settings/menu/advanced/regulatory domain and try differnet numbers. I don't have that choice on my current rom. There is also a "fix my wifi" app.
    Go into the phone enter *#*#4636#*#* and see in wifi config/wifi status, refresh stats and look for anything obvious.
    [SIGPIC][/SIGPIC]
    San Francisco Giants
    Also, make sure your mac address starts with 00 or you may have wifi issues and google is aware of this.
    [SIGPIC][/SIGPIC]
    Also, did it ever work and are you using a router. On some routers like mine you need to input the mac address thru it's software to be accepted.
    [SIGPIC][/SIGPIC]
    Unhappy still...
    Tries the first tip. Dont have that option on my rom either.
    My mac address shows as disabled and whem i tap on it notging happens.
    Tried typing the #*#*4636*#*# and it shows the wifi status as unknown and when i do the refresh it shows the supplicant state as UNINITIALIZED in capital letters.
    The RSSI shows as -200 the hidden ssid as false the ipaddr 0.0.0.0 and the id is -1 with the speed -1Mbps.
    HELP!
    Wow, disabled mac. That's the problem, but why?
    [SIGPIC][/SIGPIC]
    Not disabled sorry... it says that the mac is unavailable..
    Well, I don't know. Are you rooted to restore a backup? You could do a factory reset and start over. I would call your carrier then HTC first.
    [SIGPIC][/SIGPIC]
*#*#4636#*#* android wifi
*#*#4636#*#*.wifi
android * * 4636 * *
android supplicant state uninitialized
android wifi supplicant state uninitialized
android wifi uninitialized
help me my phone have problem in internet
supplicant state: uninitialized
supplicant state: uninstalized,mac address:unvailable
wifi uninitialized
nexus one
