Internet problem with my phone
This is a discussion on Internet problem with my phone within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I cant connect to the mobile internet with my nexus one. I don't know what the problem is i called my operator and they said ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Internet problem with my phone
    Junior Member Oreex0's Avatar
    I don't know what the problem is i called my operator and they said that they cant do anything about it, that i have to call HTC for tech support. But the problem is that i live in Sweden and i do not wish to call tech support in Brittan to solve my problem. is there some other way?
    More info needed:
    Carrier, rooted, did it ever work, any messages given on what the problem may be.
    Check over all your wireless settings like APN's, Registered on Netwwork,etc.
    Ken
    [SIGPIC][/SIGPIC]
    San Francisco Giants
    it is not rooted, it never worked, i have all the right settings on the APN and its registered on the network. they said that they could not get into the system that i should contact HTC. could it help if i rooted it?
    rooting won't help in your situation
    sounds like bad phone
    you can try a different browser other than the one you are using, like opera mini or dolphin. You do have access to the Market? ie gapps installed.
    [SIGPIC][/SIGPIC]
    i had the dolphin browser before and it did not work anyway but i can try with the opera, i have access to the internet with wifi
    so if you now have the stock browser and it don't work, it may be the phone, unless someone has an idea.
    you can google your problem and see what the results show.
    if it is the sim card would think your carrier would know that.
    [SIGPIC][/SIGPIC]
    i've tried to google it but i cant find anything so i ask here, if someone knew.
    ok
    good luck on it
    [SIGPIC][/SIGPIC]
    some other things if not done already:
    battery pull
    toggle airplane mode on then off
    if you can tap on stock browser icon, do--menu/more/settings/clear cache and history.
    [SIGPIC][/SIGPIC]
    14 times
    Did you buy the phone from google? Or a private seller?
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
*#*#4636#*#* android wifi
*#*#4636#*#*.wifi
android * * 4636 * *
android supplicant state uninitialized
android wifi supplicant state uninitialized
android wifi uninitialized
help me my phone have problem in internet
supplicant state: uninitialized
supplicant state: uninstalized,mac address:unvailable
wifi uninitialized
nexus one
