T-Mobile Nexus One MMS will not send!
This is a discussion on T-Mobile Nexus One MMS will not send! within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; It just gets stuck at "Sending...". I'm on the web2go 9.99 plan. Web works but the mms does not. I created another apn with epc.tmobile.com ...
Thread: T-Mobile Nexus One MMS will not send!
    Junior Member gary313's Avatar
    It just gets stuck at "Sending...". I'm on the web2go 9.99 plan. Web works but the mms does not. I created another apn with epc.tmobile.com and everything but it still doesn't work! How can I fix? Oh BTW, I'm new to Android and this is my first device!!
    Senior Member Luq07's Avatar
    Does your APN have the following settings:
    APN: epc.t-mobile.com
    MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    MCC: 310
    MNC: 260
    APN type: default,supl,mms
    All other settings should be blank.
    Quote Originally Posted by Luq07 View Post
    MCC: 310
    MNC: 260
    But if I set APN to epc.tmobile.com, then I can't get any web!
    Junior Member Inhuman's Avatar
    Quote Originally Posted by gary313 View Post
    MCC: 310
    MNC: 260
    you have to set 2 apn's.
    One for mms and another for data. (well thats how i did it and it works for me)
    MCC: 310
    MNC: 260
    APN type: mms
    apn: internet2.voicestream.com
    everything else is default
    APN Type: default
    then check the apn
    try that
google phone on tmobile not sending mms
nexus 4 tmobile mms
nexus 4 tmobile mms not working
nexus one mms settings tmobile
nexus one wont send mms
t mobile web2go mms settings
t-mobile nexus one cant send mms
tmobile prepaid plan nexus 4 not sending mms
why mms not sending tmobile
