SD won't Mount
This is a discussion on SD won't Mount within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Today my sd wont mount. USB debugging is check on. I have check on and off several times. Pulled battery for restart and restarted several ...
Thread: SD won't Mount
    Member jjcgolf72's Avatar
    SD won't Mount
    Today my sd wont mount. USB debugging is check on. I have check on and off several times. Pulled battery for restart and restarted several times. Any ideas before restoring? I get a ADB notification for debugging but no notification for turning on so I can connect to computer.
    Running evil 1.2
    Well completely stumped. But as "nickshertzer" said in another post, thank god for nandroid backups. Everything is back to normal.
