camera resolution problem!
This is a discussion on camera resolution problem! within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; i cant seem to take high resolution pictures. all of the picture come out 384x512 and around 30.-55.kb in size . i dont know what ...
Thread: camera resolution problem!
    Junior Member dino11216's Avatar
    i cant seem to take high resolution pictures. all of the picture come out 384x512 and around 30.-55.kb in size . i dont know what to do, i even brought the fx camera program hoping it would change the picture size. yes , i have played around with all the settings on the original camra but nothing changes, when i go to 5 megapixel to 1 nothing happends.
    Junior Member sheeno15's Avatar
    im having the same problem.
    has anyone had any luck with this?
    Android Lurker iPeck's Avatar
    Laval, Qc
    weird. Have you tried a factory reset ? (backup your stuff if you do)
    i found the problem.
    i was looking in the wrong folder on the computer.
    i was looking under the thumbnails folder instead of the camera folder
    silly me.
    thanks for the help
    Laval, Qc
    at least your issue is fixed ! hehe
  1. Battery for Epic 4G
    Last Post: 12-17-2010, 07:02 PM
android camara resolution
