Wireless N
This is a discussion on Wireless N within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hello all. Does anyone know how to get wireless N in a nexus 1? I just installed fibre optic tv and internet and have a ...
Results 1 to 10 of 12
Thread: Wireless N
    Android Lurker ceramista's Avatar
    Lisbon, Portugal, Portugal
    Wireless N
    Hello all.
    Does anyone know how to get wireless N in a nexus 1? I just installed fibre optic tv and internet and have a portable pc with wireless N. Was having trouble getting wi fi on the nexus. Had to change wi fi to g.
    Only way is to root?
    I read that Froyo 2.2 was supposed to have made wireless N available but seems it didnīt happen?
    Seems it needs a driver for the chip?
    Thanks,
    C
    2.2 has wireless n. do a search
    Quote Originally Posted by johnny cizzle View Post
    I now know it has wireless n. BUT I canīt get it to work on the nexus.
    If I set router to g/n -nexus wonīt connect
    Router does not have option for n only ( I think that is the problem)
    If I set router to g, I immediately connect with Nexus.
    With g I get slower speed on laptop.:-(
    Seems a no win situation.
    C
    You may be right,
    Does Nexus One Froyo have 802.11n? - xda-developers
    googling this does come up with several links
    [SIGPIC][/SIGPIC]
    San Francisco Giants
    Quote Originally Posted by rugmankc View Post
    You may be right,
    Yes, Iīve seen that, thank you. I donīt fancy rooting though. Call me a chicken:-)
    For everyone: I DO Google any doubt I have before posting questions in ANY forum. I know people usualy go to forums and ask silly basic questions that a simple Google search can answer. NOT me.
    My point on the first post, based on my take is that you may need an N only router. And, I have read that even then you are only going to get 2.4gz because of the N1. The only one who posted a fix was someone who had his router settings wrong.
    Good Luck on figuring it out!
    [SIGPIC][/SIGPIC]
    Ya check the router. If the N freqs are 5 GHz then I don't think you can connect.
    Quote Originally Posted by jonno2k View Post
    Thanks. Will check soon as I get home.
    also look at your connect speed and post it please
    menu-wireless & networks- wi-fi settings- then click on the router your connected to. it will give you your link speed
    Quote Originally Posted by ceramista View Post
    Can't find those details :-(
    C.
  1. Problems with push mail and showing email history.
    Last Post: 09-05-2010, 02:31 PM
android 2.2 wireless n1 trouble
how android connect wireless n
nexus one 5ghz
note2 wireless n
wireless n android
