LOCK SCREEN FAIL!!! (plus unresponsive Home button)
This is a discussion on LOCK SCREEN FAIL!!! (plus unresponsive Home button) within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Sup NXS1ers, Out nowhere it seems my NXS1 decided to quit locking the screen. Now after pushing the power button once, the screen does not ...
Thread: LOCK SCREEN FAIL!!! (plus unresponsive Home button)
    Junior Member antonio_nexusone's Avatar
    Sup NXS1ers,
    Out nowhere it seems my NXS1 decided to quit locking the screen. Now after pushing the power button once, the screen does not lock. Pushing the button a second time brings it back to life with no "Slide to unlock." The phone also comes back to life if I push the up / down buttons on the side to toggle volume while playing music, or even pushing the trackball.
    Additionally, my Home button quit working. I feel the haptic feedback when I push it, but it doesn't do anything anymore. In each application I have to "back out" to get back to the home screen.
    I've tried restoring the phone once before; however, this did not fix the issue. Does anyone have any ideas? I looked through my phone's downloaded applications and didn't see anything that seemed like it would control the lockscreen. Any apps known to mess with lock screen and cause an issue like this?
    Any ideas? Would love to have a fully functioning NXS1 again :/
    Junior Member govinnigo's Avatar
    So my phone is doing the exact same thing and started about the time of your post.
    Fixed. First make sure your back up is enabled in your privacy setting. Then do a hard reset. Power down. I removed my SD and sim cards j.I.c. then press your power, volume down and trackball at the same time. Go into bootloader then clear all. You should still have all your apps and such from backing up to the Google server.
home and lock button lg
lg ally home button not working
lg ally power button not working
lg ally screen wont lock
lg ally wont set screen lock
lg p505 home button stopped working
lg phone wont lock
lg screen wont lock
my lg phone wont lock
screen lock problem
screen wont lock lg
screen wont lock on lg phoenix
searchlg p505 home button wont work how do i fix it
why doesnt my home button work on my lg phone
why wont the home button on my lg phone work
