Nexus One with Froyo 2.2 Rebooting problem
This is a discussion on Nexus One with Froyo 2.2 Rebooting problem within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi All, I am facing a serious issue with my phone which I purchased a month back. It keeps rebooting randomly while working. I have ...
Results 1 to 9 of 9
Thread: Nexus One with Froyo 2.2 Rebooting problem
    Junior Member BlackHeart's Avatar
    Exclamation Nexus One with Froyo 2.2 Rebooting problem
    Hi All,
    I am facing a serious issue with my phone which I purchased a month back. It keeps rebooting randomly while working. I have isolated the occurences as
    1. When i connect to a wall charger
    2. While using wi-fi and browsing for a length of 15-20min
    3. While using wi-fi and making calls
    I have tried the following:-
    1. Move to factory settings
    2. Cleared the cache
    Please help me if anyone is aware how to fix this issue as its becoming junk rather than a jewel.
    My guess is that it's overheating.
    If you're rooted, try an under current kernel...
    Its not overheating. And am not rooted...!!
    Sorry!
    14 times
    You could try a Factory Data Reset. Just make sure to backup your Data first(SMS, Apps)
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    Try downloading a log cat, but I'm not sure if it will store data from before the reboot...
    FYI
    Nexus One randomly reboots itself - Android Help
    I would call HTC if none of above helps.
    Ken
    [SIGPIC][/SIGPIC]
    San Francisco Giants
    Junior Member pagalnokia's Avatar
    Buddy, i go the same problem exactly but not with Froyo 2.2 but with the latest firmware release ver 2.2.1, i tried everything single thing like you did and later on found that its the memory card issue !!! i removed the memory card and everything is rock solid and perfect now, may be you have the same problem too
    Member Rocco D'Voe's Avatar
    same BS here too!!!!!
    ever since 2.2.1 i'm getting random resets on the phone and constant freeze-ups when using wifi. I have to keep wifi off now since its become such an annoying problem.
    everything was working fine for months now this?? WTF GOOGLE!!??!??!
